Browse Forums Landscape & Garden Design 1 Feb 11, 2010 8:10 pm Hi, we have a couple of garden beds against the house which i have just bought organic soil for at this stage but i'm not sure what mulch to use that won't attract termites-are pebbles the only option. Can I use manure/compost in these beds? Do i need to put plastic between the house and the beds? Re: What mulch is safe to use next to the house on a garden bed? 2Feb 11, 2010 8:43 pm How close to the house and is it above slab height... If it is above slab height then the wall needs to be waterproofed. And the weeper hole are reduntant as ingrees could be made through them. Where you are coming from is where you are going to... Re: What mulch is safe to use next to the house on a garden bed? 3Feb 12, 2010 9:59 am The bed is the same level as the slab and is quite small. I'm pretty sure it is not against any weep holes but i'll double check. What should I do to waterproof it and can I then mix the soil with compost or manure and what are the options for mulch on top. Many thanks. Re: What mulch is safe to use next to the house on a garden bed? 4Feb 12, 2010 12:20 pm Fu is the one for Garden knowledge I don't know where you are... But heaps of membrane type products around and then add a barrier so that the membrane doesn't get beaten up by garden activities Where you are coming from is where you are going to... Re: What mulch is safe to use next to the house on a garden bed? 5Feb 13, 2010 12:35 pm If white ants are a concern it is nothing to do with the mulch. It is about giving the buggers access to your home. Avoid garden beds against a wall where ever possible. In such cases, ensure a termite barrier is not buried. Keep the soil and mulch level (even pebbles) as close to the slab height as possible. Any higher and that is where the problem can start. Many people will have soil up against a home and then blame something more trivial for the termite problem. So with that in mind the same mulch principles apply. green mulches are the very best. They don't hold water, they don't blow around and they begin a cycle of healthy soil. They feed the soils. Very important. View the mulch video. http://www.greatgardens.info/video/grea ... videos.php Look at pebbles as well but not the best for maintaining plant and soil health. Re: What mulch is safe to use next to the house on a garden bed? 7Feb 13, 2010 12:49 pm jspitz Thanks for your help-mulch appreciated! Re: What mulch is safe to use next to the house on a garden bed? 8Feb 15, 2010 1:40 pm Fu Manchu Avoid garden beds against a wall where ever possible. In such cases, ensure a termite barrier is not buried. This doesn't match with the Termite people... when we had them to come and check it at 12 months, the guy said we need to call them back as soon as the gardens are finished to recheck it. He commented that we had sections that weren't below the soil surface which is apparently a no-no. He said to make sure that the pipe was well below the soil level (not exposed) and it should go under any concrete. The type we have (which is quite standard from what I can tell) works by the chemical leaching out into the soil... so it has to be buried. Second Time 'Round Re: What mulch is safe to use next to the house on a garden bed? 9Feb 15, 2010 2:17 pm First_Timer_Ray Fu Manchu Avoid garden beds against a wall where ever possible. In such cases, ensure a termite barrier is not buried. This doesn't match with the Termite people... when we had them to come and check it at 12 months, the guy said we need to call them back as soon as the gardens are finished to recheck it. He commented that we had sections that weren't below the soil surface which is apparently a no-no. He said to make sure that the pipe was well below the soil level (not exposed) and it should go under any concrete. The type we have (which is quite standard from what I can tell) works by the chemical leaching out into the soil... so it has to be buried. That would apply to barrier methods, like Termimesh which we have, rather than chemical methods. Re: What mulch is safe to use next to the house on a garden bed? 10Feb 15, 2010 3:59 pm My house has raised paving, lawn and garden beds against it, am starting to worry about termites. Has anybody heard of or used this ? Looks like a good system and I believe it would work but is pretty expensive for essentially some pine pegs ! http://www.greenpest.com.au/ cheers Re: What mulch is safe to use next to the house on a garden bed? 11Feb 20, 2010 8:33 pm Cypress mulch is naturally termite resistant. Looks great too. Make sure you have a seat nearby when you are quoted the m2 price Al & Caitie- Building the Hamilton 278 (Coral) at Narangba Re: What mulch is safe to use next to the house on a garden bed? 12Feb 20, 2010 9:02 pm Ultimately it isn't the mulch that is the risk. It is having a garden bed along the home that is the risk. Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 3503 i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16019 Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20187 |
