Browse Forums Landscape & Garden Design 1 Jan 25, 2010 5:07 pm Hi, I was wondering if anyone in the Jandakot area had tired to grow blueberries. I have recently purchased three varieties. One tropical and two that need frost to ripen/set the fruit. I was wondering if Jandakot was too cold for the tropical blueberries to fruit or not cold enough for the tasmainian varieties to fruit? I figured buying a few of each and seeing what happened would be interesting but any inforamti8on that might help would be great!! *Built with Gemmill Homes in WA* Slab - 1st June 2009 Plate Height - 17th June 2009 Lock Up - 18th August 2009 PCI - 5th October 2009 Hand Over - 15th Oct 2009 https://forum.homeone.com.au/viewtopic.php?f=31&t=20844 Re: Blueberries, Frost and Jandakot. 2Jan 26, 2010 9:58 am They'll be fine There is a wholesale grower of these down your way. Also if anywhere is going to get a heavy frost in early spring, it's the Jandakot area Re: Blueberries, Frost and Jandakot. 3Jan 26, 2010 10:07 am Hey Fu, the Back yard aquaponic shop is in Jandakot... ...they grow heaps there and very well too I might add. Where you are coming from is where you are going to... I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10048 The HIA contract, in the term & conditions section states that "Commencment" is deemed when the drainage is started or the piers are dug or the slab is formed up (incase… 2 6182 Hi there, We've just build a new hardwood (Greybox) deck and am wondering whether firepit protective mats/surfaces are sufficient? I'm not sure that they're heat… 0 2118 |
