Browse Forums Landscape & Garden Design 1 Jan 17, 2010 5:13 pm Here's a question for the pool builders, concreters, or anyone else with a bit of knowledge on the subject. How feasible would it be to convert a concrete rain water tank into plunge pool? We don't have much land to work with, and a circular rain water tank would fit in to the available space perfectly. Ideally I'd like to have the tank installed with about 50% of the side hight underground, with the rest painted, and inside tiled. Any ideas? Re: Would this be possible? 2Jan 17, 2010 5:17 pm Yes, you can use a rainwater tank as the 'formwork', just as you would for a standard pool only it would be round. Where you are coming from is where you are going to... Re: Would this be possible? 4Jan 18, 2010 6:27 am IkonInteriors Here's a question for the pool builders, concreters, or anyone else with a bit of knowledge on the subject. How feasible would it be to convert a concrete rain water tank into plunge pool? No...an above ground concrete tank is not designed for the earth plus saturated earth pressures imposed from the external side particularly when empty. Concrete above ground tanks are design for internal pressures acting outwards...and the reinforcement helps carry the resulting tensile hoop stresses. You can use it as a former (as Onc suggested)....but I doubt the economies stack up. And it you use a below ground water tank you might as well build a proper pool. mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Would this be possible? 5Jan 18, 2010 5:26 pm Hi Guys, Thanks for your replies.. I've done a bit of searching and found a couple of pictures in an old magazine; seems it is possible to just use a topless concrete tank. Here's a few pictures I took with my phone, so sorry if they're not very clear: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Would this be possible? 6Jan 18, 2010 7:06 pm That looks nice.... and very new. ...but it might not look like that in a few years Well unless the constructor has used all manner of waterproofing. That looks about 50mm thick, the standard for water containment is 100mm. ...but of course there are things that will mitigate a long lasting product. lots of things to consider before just bashing one up. Where you are coming from is where you are going to... Re: Would this be possible? 7Jan 18, 2010 7:12 pm That looks like it's completely above ground...not half buried which was the point I was making. A thin tank would have bugger all cover to the reinforcement...one small movement...one small crack and it's all over red rover. mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Would this be possible? 8Jan 18, 2010 7:28 pm I was thinking nil cover as in nil reo tdl How about a thermal change like hot weather and the top above water level? And forgot to mention the above/below ground bit Where you are coming from is where you are going to... Re: Would this be possible? 9Jan 18, 2010 7:38 pm onc_artisan I was thinking nil cover as in nil reo tdl Even stock tanks have some reo...well the ones I've seen around here do... mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 36968 0 9828 In Qld it is a requirement that a builder must have a cost breakdown, for building a home to the same specification, with the same inclusions and the same finish. So ask… 1 4357 |
