Browse Forums Landscape & Garden Design 1 Dec 10, 2009 8:40 pm I am looking for a solution to permanently prevent any weed / grass from growing in between the garage wall and fence. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ As you can see it is going to be impossible to pull out later. Can anyone recommend a solution / product to use? We got to put it in before bricking starts. Re: permanent weed prevention on side of garage with fence 2Dec 10, 2009 8:51 pm concrete 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: permanent weed prevention on side of garage with fence 3Dec 10, 2009 8:52 pm Fill it up with gravel, at least 70mm deep (i think that is the figure I see Fu throw about) Re: permanent weed prevention on side of garage with fence 4Dec 10, 2009 9:16 pm You can't get anything in there but a compromise . The options are: Concrete but weeds will grow in any cracks or in plant or dirt debri that will build up in time. Once a year path weeder. Apply it once a year or sometimes two times a year Gravel, yep 100mm and you will still get weeds growing in the air spaces of the gravel. They will blow in on the wind, not come from under the ground. Once a year path weeder as well. Gravel, dirt dust etc will build up on this over time and weeds will grow in that. Re: permanent weed prevention on side of garage with fence 6Dec 12, 2009 6:59 am You'll need a barrier against the fence first - if you heap soil, gravel or anything similar against the Colorbond panels, they'll rust. And you'll void the warranty. We have a similar gap between our garage and the neighbour's and nothing grows there. If it did, I'd simply squirt some weedkiller on it, but we're 12 months on and so far, nothing.... Re: permanent weed prevention on side of garage with fence 7Dec 12, 2009 5:31 pm kek, thanks for the info, I'm probably worrying too much. There is still a bit of the moisture membrain there I might just tape it to the fence and leave it at that. Good luck with it. I don't know what the cost of a nice bidet seat with a 25mm air gap will be but you are obviously deducting the cost of a RPZ valve and its… 9 6985 Hey everyone Not for me or anyone I know, just generally interested. For a single allotment house, are you allowed to take the fence on both sides of your house and… 0 20892 Hi all, has anyone been ask to do the weeds in their property while in the middle of build? We are under the impression that they are in control of the site while they… 0 2779 |
