Browse Forums Landscape & Garden Design 1 Dec 04, 2009 4:37 pm Hi Guys, looks like ew have run into an issue with our neighbour over fencing and retaining walls. As we live on a hill and we are slightly higher than they are, they have cut into there block (approx 1.3m below natural ground on the boundary. however we have filled and come up about 600mm, as such there is a 1900mm difference between our yards. To avoid council regulations we both said we would build 1.0m walls, 750mm on the inside of our boundaries, we would then run the fence along the boundary line. That means the walls are 1.5m apart and thus comply with building regulations. it appears though our neighbour has decided to reneg on the deal as when i was at the block yesetrday they have put all the posts in for there wall and they are only 100mm from the fence. therefore to comply we need to build 1.5m back resulting in us losing a lot of our land and our 'side access' Our only other option is we get our wall engineered and council approved to build closer than 1.5m but obviously this is at our expense.. Otherwise we just suck it up and lose the additonal land even though we had a verbal agreement. the same tradesman is doing both walls and he knew the scenario. When i asked him about it he said the neighbour changed it last minute and our neighbour taken it on himself to do that eg. the risk of building closer. What would you do, anyone had similar problem. im worried now if we build our wall where it was oringally planned it doesnt comply and we would be the ones with the issue? Re: Retaining wall, boundary issue with neighbour 2Dec 04, 2009 5:30 pm I'd imagine that will be the case. The only other way around it is if you had some sort of legal agreement signed by both parties. If it was verbal, then I don't think you have much to back you up. Re: Retaining wall, boundary issue with neighbour 3Dec 04, 2009 7:19 pm Thanks Fumacnchu, Is there any law about when you must have a retaining wall? eg is there anything stopping me from not putting one in and running my soil close to the fence before slightly tapering off? I Re: Retaining wall, boundary issue with neighbour 4Dec 04, 2009 7:23 pm well all the ones around Perth are on boundries. we have a 1.5m retaining wall on our side of the boundry. Re: Retaining wall, boundary issue with neighbour 5Dec 05, 2009 10:20 pm I know in our development, you can't build a retaining wall closer then 450mm to the fence, unless its part of the fence. Perhaps there is a rule like that in your local DCP? Interesting... Built with Eden Brae Now building with Fairmont Homes NSW thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16358 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 46329 Hello, We are about to build and the plans show a part of the exterior wall is being built on top of a limestone retaining wall. Does this mean the retaining wall will… 0 6987 |
