Hi
I have a small court yard with 3m x 6m area of lawn I would like to remove, is there an easy way to remove it? Is digging the easiest option?
Thanks
Browse Forums Landscape & Garden Design 1 Oct 15, 2009 2:34 pm Hi I have a small court yard with 3m x 6m area of lawn I would like to remove, is there an easy way to remove it? Is digging the easiest option? Thanks Re: Removing lawn in a court yard 2Oct 16, 2009 10:23 am There are lots of threads on this already Roundup and then digging is a common method, depending on which grass. If you skip the roundup bit the grass'll come up forever through whatever you replace it with. Re: Removing lawn in a court yard 3Oct 16, 2009 10:56 am englyn There are lots of threads on this already Roundup and then digging is a common method, depending on which grass. If you skip the roundup bit the grass'll come up forever through whatever you replace it with. Even with roundup you need to give it a chance to die. Then, when you think it's dead - kill it again Damn grass - I hate grass !! Re: Removing lawn in a court yard 4Oct 17, 2009 10:45 pm JilaMint englyn There are lots of threads on this already Roundup and then digging is a common method, depending on which grass. If you skip the roundup bit the grass'll come up forever through whatever you replace it with. Even with roundup you need to give it a chance to die. Then, when you think it's dead - kill it again Damn grass - I hate grass !! Good idea I will just that. Re: Removing lawn in a court yard 5Oct 17, 2009 10:58 pm It's more than a case of just bunging on round up or similar glypho product. The lawn needs to be actively growing for any result to be had. Otherwise you think it's dead and comes back in your new pavers It has to warm or better still, hot. Then water it well and give it's last meal of a healthy dose of hi nitrogen fertiliser, granular weed and feed is excellent and cheaper than lawn fertiliser. Lots of sulphate of ammonia loaded with nitrogen for growth. Then a week later smash it with glypho (round up). Make sure when you mix up the roundup in the sprayer you put in a splash of seasol. This alone can be a difference in it working or not. (seasol is far better than using the traditional urea). Also add in two or even three drops of dishwashing liquid. This will make the mix stick to the grass leaf rather than run off as most can do. pop the drops of dishwashing liquid in after you have filled it also spray in the morning only, and not before rain or irrigation. wait three weeks before removing and don't water it after the application. I've filled, levelled and compacted around 100mm of roadbase in preparation to lay some outdoor court tiles. Prior to doing the final compaction, I dusted the top with… 0 3041 can someone with more experience give me their insight? land is pretty much flat its pretty much at the top of a hill. left and right neighbours are flat in line with my… 0 7445 2 4367 |
