Browse Forums Landscape & Garden Design 1 Oct 14, 2009 4:26 pm Hi What can I do on my council verge? Paving or lawn. Is it possible to put a small retaining brick between the boundry of my neighbour's verge becaue my land is higher than their? Thanks Re: What landscaping on Council verge 2Oct 14, 2009 4:48 pm re council verge; depends on your council rules really, best to ask them. A lot of councils let you put garden beds etc. but the council has the right to dig it up and wreck it all. Hard surfaces, eg paving might be pushing it. Re: What landscaping on Council verge 3Oct 14, 2009 9:44 pm I know here in Perth some councils are actively encouraging the re-vegetation of verges instead of using lawns. However only certain trees are approved (check your local council, water authority and telstra regulations first). Generally a "soft edge" must used at the curb. The depth of the soft edge varies from council to council but 1- 1.2m is the most common range. This is for safe exiting of vehicles. Not so much for you but more for council and utility workers. Check out your local native specialist nursery because they commonly have good knowledge of what species are used by local councils and others who are re-vegetating their verges. Check out regulations on gravel, many don't allow it for saftey reasons. Soft mulches and low local natives are a go. I don't think you'd get away with a small retaining wall. Re: What landscaping on Council verge 4Oct 17, 2009 8:17 am Just recently I checked Stirling CC verge rules. They require 2m clear from the verge for people who choose to walk their dogs on your side. The rest needs to be non-obstructing low planting, you can also apply to them and they will come and plant a tree of their choice for you. However, each council is different and rules are different and change with time. Best contact your own CC good luck. Maggie Even if it's not being sub-divided and you want to keep it as Torrens title, you will still need to talk to a town planner or Council themselves, to see if they will allow… 1 11014 We've had the offer of a short term tenant whilst waiting for CDC/DA home approval and demolition for our knock down rebuild. It would achieve a pretty low rent as it's… 0 13744 This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 3643 |
