Browse Forums Landscape & Garden Design 1 Sep 14, 2009 5:41 pm Hi I have an old lilly pilly hedge across the front of my property which sits behind an old wire fence. The hedge is now gappy at the bottom as it hasnt been pruned well. Can I plant something underneath it to fill the gap between the ground and the bottom of the hedge (approx 60cm)? Suggestions? Or can it be tempted to grow to the ground again with pruning? Thanks for your ideas Re: Filling gaps in an old hedge - ideas? 2Sep 14, 2009 6:19 pm I doubt you'll get to reshoot easily. I'd look at establishing a lower hedge in front of it and using the articles and links in the stickys above. As far as choice goes, you can use any shrube that grows to around 2m to clip into a low hedge Maybe something yellow for contrast. Duranta sheenas gold or gold diosmas easy as Re: Filling gaps in an old hedge - ideas? 3Sep 14, 2009 6:34 pm Sorry but am a newbie - what articles and what's a sticky? Keen to find out shrubs that can be hedged in front of current hedge... did you mean right under it or slightly in front - which in my case would be facing the inside of the hedge looking toward the house. DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31280 That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17361 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7465 |
