Browse Forums Landscape & Garden Design 1 Sep 10, 2009 12:37 pm Does anyone know ideally how much side access you need to make it practicle to put in a pool. Is it mainly used for digging the hole, Do they want to get the whole cement truck up there or just a dingo? I've called up a couple of pool places and I didnt get an answer.. Re: Side Access for pool 2Sep 10, 2009 1:46 pm Digging out for a pool would require a bit more than a dingo I am guessing they would need access for the excavator and bobcat, and possibly the concrete truck. If the truck can't get in, they could always pump the concrete. 2100 should be enough to get machines through (some would fit through 1800). If you are accessing it through an existing fence, and took out one section of the fence you should have 2700 wide access. Blog is now up - http://www.jbdave.blogspot.com/ Re: Side Access for pool 3Sep 10, 2009 9:18 pm With a side access of only 2100, it's going to be expensive and time consuming but doable for the right contractor Re: Side Access for pool 5Sep 16, 2009 3:38 pm It will probably involve some considerable engineering if it is close to the house. If the pool is built after the house and both have concrete construction there may need to be underpinning or extended footings so the angle of repose isnt a factor to weaken either of the structures Hi, Building a new place and I have limited space from garage to fence. 3130mm width, then opens up over 5000mm once I pass tmy garage. I need a fence that goes from… 0 3330 For reference, this is the Austlii reference. My take on this is, that they would be breaking the law denying access to a homeowner in Victoria, or their agent from having… 1 9099 |
