Browse Forums Landscape & Garden Design Re: Treated pine for vegie garden? 28Aug 10, 2009 12:06 pm A possible solution? I've got a veggie patch enclosed by sawn treated pine and didn't realise there might be some negative effects until I read about them on this site ([expletive deleted] killjoys!) . But for my sweet potato strip-plot I've enclosed the area with plastic wire cut down to about 20 cm made rigid by recycled plastic stakes (from Bunnings) cut in half. Now the trick is to heap half rotted compost around the inside edge of the wire to stop the middle-soil spilling out. And ... and one can put bamboo sticks through the top holes in the wire (side to side) and hopefully keep cats out. This is still a work-in-progress and is yet to be proven in practice but undoubtedly come summer it will be a veritable cornucopia of vegetables! Re: Treated pine for vegie garden? 29Aug 11, 2009 1:14 pm Quote: veritable cornucopia of vegetables! or you could just say you will have lots of veggies Re: Treated pine for vegie garden? 30Aug 11, 2009 6:42 pm Your veggie patch would need to be more cone-shaped for it to be a veritable cornucopia Do the hard jobs first. The easy jobs will take care of themselves. - Dale Carnegie DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 4647 I’m just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 51968 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 1290 |
