Browse Forums Landscape & Garden Design 1 Jul 20, 2009 7:19 pm Has anyone used concrete sleepers for their retaining wall. Our site plans say: Approx 0.9m high @ highest point Approx 1.2m from inside face of wall to brickwork Approx 0.65m from inside face of wall to boundary Would concrete sleepers be the best way to go do you think? Advice appreciated. Re: Concrete sleepers as a retaining wall 2Jul 22, 2009 7:17 am Has no-one used concrete sleepers for retaining? Re: Concrete sleepers as a retaining wall 4Jul 22, 2009 7:44 am We are planning on using concrete sleepers for our retaining wall using steel uprights. From our investigations, the cost of retaining walls will be dependent largely on the site and purpose. Councils have rules on how high a retaining wall can be and where a retaining wall can be placed before it will need an engineered design. For example careful consideration needs to be taken if a wall is right on a fence line due to the forces created by the fence catching wind. Also need to consider that installation is liekly to be a 2 person job because the sleepers themselves are pretty heavy. Around 50kg I believe. There are a couple of companies supplying concrete retaining wall sleepers that I am aware of. Check out Retaining Australia and Real-Crete. Prices are around $30-$35 per sleeper with dimensions of 1800mm x 200mm x 70mm. Re: Concrete sleepers as a retaining wall 5Jul 22, 2009 6:15 pm Thanks for that, I will check the info. Much appreciated. Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5814 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16396 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 7093 |
