Browse Forums Landscape & Garden Design Re: cost of soakwells 21Jul 24, 2009 12:23 am our home wont be approved by council unless with have soak wells! Ive been quoted $2720 for a 1500 by 1500 and a 1200 x 1200. can you get 1500 by 1500 or is that a stuff up? quote sounds ok i think Building the Pegasus New Generation Bletchley Pk, Southern River Land purchased 03/2009 Contract 06/2009 Prestart 09/2009 Land cleared/sand Pad 10-12-09 Fittings done 17-12-09 SLAB!! 18-12-09 Brickies started 27-1-10 Roof Started 2-3-10 Lock Up 13-5-10 Re: cost of soakwells 22Jul 24, 2009 12:41 am Soakwells are a wrought! I would ask for ag drain instead. they are much more efficient in what they do. Also don't get the bloody things connected direct to the gutter. Have a grate the water flows into instead. This prevents your eves from flooding when the soakwell backs up in heavy rain, and it will. Sometimes water and sand is forced up through paving as well. Try have them linked to each other where possible, not all your down pipes flow the same amount of water. They need to go a minimum 300mm deep and I strongly suggest you check the job where possible. I have seen too many rip off jobs with the soakwells or ag drain buried just under the sand by fellas that disappear after its done. Re: cost of soakwells 23Jul 24, 2009 9:18 am ladsos our home wont be approved by council unless with have soak wells! Does you council carry out inspections? Don't know what building stage you are at, but has the council fronted up for any of the required inspections todate? If they haven't then don't rush in to install soak wells. If they decide to do a final then wait for them to tell you. Don't rush in for something you don't really need. Re: cost of soakwells 24Jul 24, 2009 11:56 am Fa Manchu who does these Ag drains and how much? they do look good. i had bad problems in our old house with the down pipes leaking! Building the Pegasus New Generation Bletchley Pk, Southern River Land purchased 03/2009 Contract 06/2009 Prestart 09/2009 Land cleared/sand Pad 10-12-09 Fittings done 17-12-09 SLAB!! 18-12-09 Brickies started 27-1-10 Roof Started 2-3-10 Lock Up 13-5-10 Re: cost of soakwells 25Jul 28, 2009 11:46 pm You can get them from most agricutural suppliers like Mirco bros. There's one in Henderson. Bunnings stock it as well. As for people who install it, well you'll need to hit the yellow pages but first check the Homeone home page Re: cost of soakwells 26Nov 13, 2009 12:05 am Digging up an old thread, but... What do you do if you have limestone 600mm or less below your surface and you have a cottage block? Were trying to get soakwells in, jackhammer and shovels out the back (600x600 x 4) and excavator out the front(1200x1200) Its not enough soil to adequately cover soakwells and the water just sits in the soil anyway so im guessing an ag drain wont work. Any other ideas before the fun weekend starts? 7 12054 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37262 Fair Trading can issue orders to rectify and complete but once the matter goes to NCAT these orders are automatically vacated. You will have to terminate contract and sue… 21 29780 |
