Browse Forums Landscape & Garden Design 1 Jun 15, 2009 7:03 pm i need about 60 meters of retaining wall does anyone have any idea's where i can buy cheaper h section and pimne sleepers from?? im in south gippsland, but im in melbourne everyweekend... cheers Re: treated pine and h section steel 2Jun 15, 2009 8:24 pm Yes I usually go to Surdex Steel to get mine or a steel merchant. Looking at the Surdex website they have a branch in both Morwell and Dandenong so would be good for you. 100UC H beam is just under $50/Lm, the C channels for the ends are roughly $10/m less. As for the sleepers ring around some timber supplies and buy by the pack to make it cheaper and get it delivered (unless you have a truck or heavy trailer) Re: treated pine and h section steel 3Jun 17, 2009 9:14 am I just used the the sleepers as the "Joiner" for my retaining wall. Just concreted them in (600mm) and they have worked perfectly. A galv carriage bolt through each end. Main reason was budget. A 200mm x 50mm x 2.4m $13.00 each from Bunnings. Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14442 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6585 Iām just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 52857 |
