Browse Forums Landscape & Garden Design 1 Jun 14, 2009 8:01 pm Hi guys Most grateful for any advice. I need to build retaining walls round most of my houses's footings to prevent the ground falling into the space under the house. I'm planning on placing the retaining walls on top of the existing concrete footings. The maximum height I need is 780mm. I would like to bolt I and C steel sections to the concrete footings and then insert something that is no more than 90mm wide in the gaps. I was thinking concrete sleepers, hebel panels, etc etc. It has to be something that can be cut to height so I can attain exactly 780mm. Does anyone have any suggestions what product I could use and where I could get it? I'm in SE Melbourne. Thanks for any help. JB Re: Another retaining wall question - DIY concrete?. 2Jun 29, 2009 10:36 pm From the research tha I have done, Hebel suggst that you don't use their blocks as retaining walls; probably due to the support etc. I would suggest concrete panelling... But again investigate Hebel as an option.....you can read the details at www.hebelaustralia.com.au if you havent already done so!! Re: Another retaining wall question - DIY concrete?. 3Jun 29, 2009 10:43 pm Form it, pour some concrete, vibe, cure and remove the front form exact to height Where you are coming from is where you are going to... Re: Another retaining wall question - DIY concrete?. 4Jun 30, 2009 6:54 am James Bond I would like to bolt I and C steel sections I seriously doubt that bolting would be successful long term, the bolts will come loose. All the retaining walls Ive seen have the steel/timber either concreted in or set into a deep hole. Re: Another retaining wall question - DIY concrete?. 5Jun 30, 2009 10:01 am If you use concrete block and corefill the blocks or cast concrete as suggested by onc_artisan, you can always use chemset or something similar to bolt the steel sections. Regards, Ari Ari & Scott Darwin, NT Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5108 Hi Would love some advice on a DIY project I've dived into that's now keeping me up at night. We've got a cool 1970's Mid Century style house here in NZ and have always… 0 3985 0 10919 |
