Browse Forums Landscape & Garden Design 1 Apr 25, 2009 10:11 am Hi All, I need to put a retaining wall on my block, approximately 10-12 m long. My front door looks out onto this retaining wall, which falls from a height of about 1m to nothing along its length. Based in Melb. As you can easily see this retaining wall from the front door I'd like to look into different materials that are available. Does anyone know of the differing materials (stone/wood/link blocks, etc) that can be used, and their relative costs? (Websites/images would be good, or even a showroom to go and see). Thanks in advance, Rob Re: Retaining Walls 2Apr 25, 2009 4:53 pm hey rob, don't know if this will help but heres some piccies my parents retaining wall built a couple of weeks ago - obviously she's not quite finished but still looks pretty good! leftover double size bricks were purchased from ebay (leftovers from someones build) to build this retaining wall. i think mum paid about $400 for about 700 bricks. (this size bricks sell for about $1200 per thousand) all together the wall cost about $700.00 and is about 35m long and 70 cm tall, plus stairs...gotta love ebay!!! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ i have also included a pic of another retaining on their property made of sleepers - i think the bricks look way better! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 2014 - Prepping to build the Soho 4 with Plantation homes, industrial style 2009 - Built the Brampton with Coral Homes viewtopic.php?f=31&t=15399&start=280 Re: Retaining Walls 3May 10, 2009 12:46 pm Check this website http://www.australbrick.com.au (VIC) Currently, there is landscaping package till end of June. If you have time, go to one of the display centres and ask the staff about it. Re: Retaining Walls 4May 10, 2009 2:41 pm did you put concrete footings down for the brick retaining wall finished building 40 square home on 5 acres with perry homes.working on the landscaping just finished pool deck with ://forum.homeone.com.au/viewtopic.php?f=31&t=2217 Re: Retaining Walls 5May 10, 2009 6:27 pm Love the brick wall! Hopefully you've got the drainage sorted behind the wall... Did you put up any starter bars through the footings? Electrical Engineer... Don't hold that against me... And keen owner builder... Mainly the building part!! Re: Retaining Walls 6May 10, 2009 6:37 pm I hope so to both Where you are coming from is where you are going to... Re: Retaining Walls 7May 29, 2009 5:48 pm Hi - I'm a newbie to this forum and only my second post (after a brief intro posted yesterday..) I have a question about retaining walls. I'm building in Perth and would like to know if anyone can recommend a company that does residential retaining walls at a competitive price. (Am on a budget roll here). I don't know much about them, the material (i.e. stone or bricks etc..) that they use and how much it would cost... I have attached some photos of the site below. The other one is a bit blurry but you'll have a fair idea on the lenght of the slight elevation that would need retaining. The fence will have to be installed on the retaining wall eventually. Thanks! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ ********************************************************** Building our first Japanese-theme inspired home and loving every minute of the experience! Re: Retaining Walls 8May 29, 2009 10:54 pm Will the retainer be formed on the fenceline? Where you are coming from is where you are going to... Nope, only on the inside, I've literally has my ears to the brick outside and can't hear anything. I can sort of 'reset' the noise by pressing firmly on the studs. This… 10 14144 Oh no! I would use a can of expandable foam ( there are some that will take render) then cut it back and render over the top 1 5310 Good questions but the best answer will be obtained by visiting (ie: interviewing) a couple of house designers and/or builders and ask them. You may find it challenging to… 2 3625 |
