Cypress Pine for Decking stump
I have been quoted a pretty reasonable price for a merbau deck and one of the material used is a 100 by 100 Cypress pine stumps.
Is Cypress pine stump suitable as i thought only H4 treated pine should be used as stump on the ground ?
Thank you
Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks
7/08/2023
3
Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or…
8/09/2023
I’m just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise…
