Browse Forums Landscape & Garden Design AG pipe 2Apr 04, 2007 7:30 am Dig your trench about threee times the width of you pipe and backfill it with drainage gravel. Make sure the water has somewhere to go at the end of the pipe, ie-stormwater system.
Cheers, John Re: need help with an ag pipe 3Oct 14, 2009 9:25 am Hi Guys, I know this is an old post but just wondering if anyone can give me ideas. I need to run ag pipe along the front of my garden as there is a little slope. But i dont think (or i cant locate) any drainage to connect my ag pipe to. Is there any other solutions i can use? Re: need help with an ag pipe 4Oct 14, 2009 9:35 am snistr Hi Guys, I know this is an old post but just wondering if anyone can give me ideas. I need to run ag pipe along the front of my garden as there is a little slope. But i dont think (or i cant locate) any drainage to connect my ag pipe to. Is there any other solutions i can use? Is there a down pipe from the roof? If so, you could dig up where it runs underground and cut a whole in the top of it (as the other storm water from the roof will NEVER completely fill a storm water pipe) and run it into there. Usually there is a pipe that sticks out of the ground at the front of the house that is access to where the storm water flows into the street gutter system. It is usually near your front tap. Or is it just too far away from anything? Re: need help with an ag pipe 6Oct 15, 2009 12:12 pm snistr well thats where i have the problem. I cant seem to see where the storm water pipe is. I dont know where it runs. Is it a new house? If so it will be on the plans. If not, then you can follow it out about 1 meter from the down pipe but where it goes after that is anyones guess. Sorry mate OK it's been a little while! I've been busy getting time where I can to work on this. I started by grading a pad (borrowing a… 26 19968 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7298 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4835 |
