Browse Forums Landscape & Garden Design 1 Mar 24, 2009 12:44 pm I was chatting to someone recently who was suggesting that I use steel for the sub frame of my backyard deck with Merbu on top. I have built decks before and always used Treated Pine/Merbu. Has anyone used Steel before? Are there any disadvantages? Advantages? What are the cost diffferences? Cheers, Tim -------------------------------------------------------- Built 'Cremorne 41' with PD - Handover took place in Nov '08 http://homeforourcherubs.blogspot.com/ Re: Anyone ever used Steel as a frame for a deck??? 2Mar 24, 2009 6:15 pm It will cost more but will last forever and be gun-barrell straight. You can get decking screws to suit steel joists. Re: Anyone ever used Steel as a frame for a deck??? 3Mar 25, 2009 8:18 am Yes i have it worked very well i built it close to the ground so choose steel to prevent rot/termites etc etc i used galv angle (bolted to concrete slab,steel thickness=6-7mm) instead of a face plate and seam welded my steel joists onto this. at half span i had welded another vertical support post and put this into a concrete footing for each joist. then it was just a matter of screwing the galv wingteks (screws that screw straight into steel up to 3mm i think)straight onto the joists didnt even need pilot holes (only on ends) the deck spanned about 3.5m and there was no bounce in it at all cheers Re: Anyone ever used Steel as a frame for a deck??? 4Mar 27, 2009 10:21 pm dinga Yes i have it worked very well i used galv angle (bolted to concrete slab,steel thickness=6-7mm) instead of a face plate and seam welded my steel joists onto this. Can I ask what size steel did you use for the joists? Wall thickness and type (RHS, SHS, C section or Angle?) I'd never considered building our deck from steel, and seeing I work with it all the time it should have been a more logical choice for me instead of timber, just never thought of it as I had never seen it done before. Cheers Re: Anyone ever used Steel as a frame for a deck??? 5Mar 28, 2009 2:37 pm I was looking at the steel one my self finished building 40 square home on 5 acres with perry homes.working on the landscaping just finished pool deck with ://forum.homeone.com.au/viewtopic.php?f=31&t=2217 Re: Anyone ever used Steel as a frame for a deck??? 6Mar 30, 2009 9:52 am from memory it was 2mm galv shs 50 x 50 (could have been wider though 50x 75 rhs even, did it 3 yrs ago) it spanned 3-3.5m and had a support post into a footing in the centre of each joist the other side had the angle fixed to a timber wall. Re: Anyone ever used Steel as a frame for a deck??? 7Mar 30, 2009 10:13 am There are specific sizes for deck/floor joists, contact your local steel supplier. Re: Anyone ever used Steel as a frame for a deck??? 8Apr 06, 2009 1:15 pm Thanks guys - gonna have to look into the pricing side of things. Cheers, Tim -------------------------------------------------------- Built 'Cremorne 41' with PD - Handover took place in Nov '08 http://homeforourcherubs.blogspot.com/ Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14465 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8063 Hi, I have a steel frame house which was built 2 years ago. When you are down stairs you can hear clunking noises when someone is walking around. We were told if you… 0 4466 |
