Browse Forums Landscape & Garden Design 1 Mar 12, 2009 7:22 am Hi All,
Looking at creating a kids play area in the backyard and wondering what is better/safer to use for the edging Red Gum or Treated Pine sleepers? I know Treated Pine obviously has some nasties in it - but can you paint/stain it so they don't leech out?? Thanks. Re: Red Gum or Treated Pine Sleepers? 2Mar 12, 2009 7:25 am search treated pine sleepers and there is plenty of info on the forum already After 4 years - we're in! Re: Red Gum or Treated Pine Sleepers? 3Mar 14, 2009 2:27 pm Treated pine has no nasties that can be released unless you burn it. It's a chemical process and once the treatment has cured (takes 3-6 wks after processing) you cannot release the CCA until the timber is burned.
I would go for treated pine. It's a plantation timber so is better for the environment (renewal resource), and it lasts a lot longer than the hardwood you're thinking about. Re: Red Gum or Treated Pine Sleepers? 4Mar 14, 2009 5:49 pm I agree. The redgum will attract termites and will not last as long. Put a coat of paint on the treated pine to make them look a bit nicer. DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6652 I’m just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 52897 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 11746 |
