Browse Forums Landscape & Garden Design Re: painting concrete 2Jan 10, 2009 8:17 pm is it outside in the open or under cover?
i painted underneath my old house with a concrete paint and even though after a few years it did start to peal up where water constantly sat the rest of it was fine, so id say under cover painting is easy and effective for sure, cant speak for outside though if thats the case Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: painting concrete 4Jan 10, 2009 10:39 pm not sure if the same stuff will work outside, i just grabbed it from bunnings Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: painting concrete 5Jan 16, 2009 4:17 pm Hi Billdsl
I suppose it's not exactly like what you want to do, but what I did was seal the concrete in our garage. I bought all the materials from the concrete warehouse here in melb, don't know if they're national, but he said to avoid peeling etc, to apply the first coat with a 50/50 ratio of paint to solvent. The solvent will help the paint to be absorbed into the concrete. The second coat you can still use any left over mixture (solvent/paint) and just add more paint to it. It all depends on how many sq/m you are doing etc. Really happy with how it turned out though. Hope it all goes well for you. Chris Re: painting concrete 7Jan 16, 2009 11:02 pm chuth77 Did you have to acid etch the concrete first? No - i don't really think it's a requirement unless you're dealing with concrete that's been around for a while? considering mine was pretty new, I just water blasted it. Re: painting concrete 8Jan 17, 2009 7:41 am thanks for the food for thought...i am nervous about it peeling but wonder if the solvent/ paint ratio would work...will have to think some more, i don't think it's really in our budget now, with things costing us more than first thought Re: painting concrete 9Jan 17, 2009 8:29 am thanks for the tip jembsb, ill be doing the garage floor in the new house once its built so this might be the key
the name of the paint i used is berger jet dry, another post by someone here a few days ago reminded me of the name, just got it from bunnings Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5016 Thanks mate, is there a standard off the shelf type breathable product I can apply DIY? Thanks 2 8187 |
