i am going to spray all the weeds and unwanted grass in preparation for turfing in 2 weekends time. We are getting 10 metres of underturf delivered tomorrow arvo and i was just wondering if i spray this afternoon, am i able to start spreading the underturf over the sprayed weeds the day after?? or should i be waiting?
Cheers
Roundup Question
Page 1 of 3
Cheers
Ed
after 10 days it is considered safe to plant in the soil as is is a type of salt that breaks down into what is considered harmless compounds. You are putting soil on top though so you may get away with it before then.
spray in the morning, make sure it doesn't rain and it has a whole day to be soaked up by the unsuspecting weed
as davinci says, rotary hoe the weeds into the soil. they won't be back
There is a spray called "fusilade" available from ag suppliers. smallest quantities sold is 1ltr and that covers about 1 hectare! It costs around the $150 mark. (what does a bobcat cost?) It works the oposite to weed and feed type lawn herbicides. It won't harm your roses or shrubs (or broad leaf weeds) but will 100% guaranteed kill any grass, palm, agapanthus (all monocot plants) it touches. dead. and fast!
Now this stuff is not freindly but safe to use provided you wear a mask, long sleeves and long pants, covered shoes and don't spray in windy conditions or before rain and retic. spray in the morning too so it has the whole day of sunlight to be absorbed through the leaves.
couch gone, buffalo gone, kikuyu GONE! mmmuuuu hahahahh
Ed
ahh but add seasol and then see that turned on it's head
Are you sure it will work? Many acres, many years, many blackberries, many ragwort.. the metabolism slows to a stop in drought - it's only water through the root system that makes the plant breathe again and then it will succumb to the weed killer. If you think it will work I will try, but I have my doubts...
It has allowed me to spray when I normally may not and still maintain results. (ie in heat)
No doubt what you say is correct and spraying after rain is a good idea but not always practical in summer. Add the seasol and you will still get results, not as goos as at the particular time you have mentioned but results none the less which is great when you can't pick and choose your spray days too much
I used to buy for $6/litre - cheapest is $20...
For urea it is one teaspoon per 5 ltrs or thereabouts.
It is called Garlon 600, available from ag suppliers, and similar to other poisons, costs well over $100 for a litre. The results are impressive though. You don't have to wait until the blackberries are in flower, unlike some other specialist blackberry poisons, and once diluted a little bit goes a long way. Roundup is hopeless on blackberries in our experience.
...well not good for us. nasty stuff but good in the sencse that when used safely it is about the only effective means to an end for the blackberries.
good stuff that. The same as the domestic blackberry and woody weed killers but far far stronger concentration of tryclopyr which is what is in it
Just about to spray Garlon... do you recommend Seasol with this too?
And what's best for bracken? Garlon doesn't work.
Thanks
Ed
Having been lucky not to have encountered bracken fern, can not say what will be good for it.
It's ineffectiveness so far may lay in the fact that Ferns take up nutrients and water very slowly.
If i said what to use I would be making it up.
Sorry you just found my Kryptonite
What you can be assured of is that adding seasol to whatever herbicide is effective will "amplify" it's effect just as well.
2
You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap…
20/07/2023
1
I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If…
7/08/2023
1
how imperative is the timing of the answer?
