Browse Forums Landscape & Garden Design 1 Nov 27, 2008 8:09 am Hello all,
Without coming across to spam-ish, I wanted to let you all know that Beacon are doing a 'Friends of Beacon Sale' for 3 days only, from next Tuesday morning. The sale is 20% off all exterior lighting - online and in store (just mention the sale at checkout). May be helpful to those wanting to save a few dollars. Cheers Steve Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28804 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8810 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8551 |
