Browse Forums Landscape & Garden Design Re: Grass in the backyard 22Nov 19, 2008 12:29 pm Everything I know, I learned from SBS. LATEST: Frame Complete http://metricon-mercer.livejournal.com Re: Grass in the backyard 32Nov 29, 2008 7:59 am No typo definately the price!!! Tracey & Paul Taylor Living in Marriott Waters Burbank Homes - Camellia 2900 (29.8sq) Land settlement - 8/05/2008!!! Building started - 5/06/08!!! House settlement - 17/10/08!! YAY!! Re: Grass in the backyard 33Nov 29, 2008 8:39 am The brand of seed you use will most likely be the reason why it was patchy. Nearly every seed available retail has a low germination rate and your result is fairly typical. Always choose Munns (not their budget one though) Munns have the best seed quality available and the highest germination rates of all the seeds available. I would try that before blowing money on hydroseeding.
It is a bit gymicey to me. What seed do they use? What is the germination rate of the seed they use? What type of seed is used? In most cases you won't know, when you buy a Munns seed packet it tells you exactly what you are getting. hydroseeding is normally used in large areas where it does become cost effective. It also slows errosion in new construction areas and stops mess blowing around. I would not suggest using it domestically, much better options. Re: Grass in the backyard 34Dec 18, 2008 12:28 pm Fu Manchu The brand of seed you use will most likely be the reason why it was patchy. Nearly every seed available retail has a low germination rate and your result is fairly typical. Always choose Munns (not their budget one though) Munns have the best seed quality available and the highest germination rates of all the seeds available. I would try that before blowing money on hydroseeding. It is a bit gymicey to me. What seed do they use? What is the germination rate of the seed they use? What type of seed is used? In most cases you won't know, when you buy a Munns seed packet it tells you exactly what you are getting. hydroseeding is normally used in large areas where it does become cost effective. It also slows errosion in new construction areas and stops mess blowing around. I would not suggest using it domestically, much better options. We are looking at starting our backlawn at the moment, about 200sqm so not interested in using roll out, which we plugged at the front. Had done a bit of research into the munns, what stuff do you think is their best seed Fu Manchu? Re: Grass in the backyard 35Dec 18, 2008 6:15 pm The arid for sure. It has an excellent germination rate too. Re: Grass in the backyard 37Dec 18, 2008 10:01 pm for others reading this, the Munns "sun and shade" is a great option when any shade is across the area to be planted. Re: Grass in the backyard 38Dec 18, 2008 10:24 pm Most lawns are extremely water hungry
We are going to try out a native lawn for our new house. Weeping grass (Microlaena Stipoides) requires minimal watering once established. Re: Grass in the backyard 39Dec 18, 2008 11:13 pm great idea excellent
There are loads of good options for alternatives to the common turfs we know. Re: Grass in the backyard 40Dec 18, 2008 11:21 pm I will take a pic of the pooch cooch I planted 35 days ago....
It is by far the best grass seed I have ever used and the results speak for themselves. I have tried lots of different brands (like brunnings etc) and this stuff is phenomenal. DIY, Home Maintenance & Repair Please help me to answer this question , it will help me a lot as i can go to buy confidently with your recommendation: I want to put synthetic turf in our backyard for… 0 5540 DIY, Home Maintenance & Repair That laser level looks lovely! We bought one for less than a quarter of that price off eBay. It worked really well for us and it's still going now, five years later. After… 1 16711 It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full. What is your soil type? Soak wells need sandy soils. 10 9011 |
