Browse Forums Landscape & Garden Design 1 Aug 20, 2024 6:38 pm New house with bare driveways and perimeter pathways. They've just scraped the whole block and we have pretty much sand and hard clay soil. Until we save enough and get the driveway and around the house pathways done, what do you guys recommend to seal the surface for cars and pedestrian traffic? I've heard 20mm grade 2 crushed rock or Asphalt profiling compacted to 50-75mm ? Is that the go ? We dont have heavy vehicles just a 4wd ute and family sedans. I think we'll end up granite concreting the whole lot so anything that helps build a firm base for the future would be preferable. Cheers, Please read what the conditions are when receive final payment invoice. 2 15166 Make sure you use appropriate flexible isolation joint between external concrete and building slab/footings for movements. A 10mm Abelflex is ok. 1 11566 Thanks for the photos. You need to know whether the inflow or the overflow pipe is leaking and this is a simple process of elimination. INFLOW: The vertical riser… 4 15530 |
