Browse Forums Landscape & Garden Design 1 May 16, 2024 9:34 am Hi all. Looking to do a 5 acre property fencing with 100mm copper logs fencing. 200mm ends. Land is sloping an hard to get machinery in. My question is. If I do the holes with a 100 mm auger Min 600mm deep. Can I put a steel round cap on top of log an bash it down by hand with a sledge hammer. Without doing 200mm hole an packing it in. Wire will ne on outside of pole with u clips. Wondering if poles will get movement. Not many trees around fence line for falling branches. Thanks guys DIY, Home Maintenance & Repair We have a hot water copper pipe that runs from our hot water unit on one side of our house under a concrete slab to our bathroom and laundry...old house so not ideal. The… 0 6524 DIY, Home Maintenance & Repair Hi, I have an old fence/barrier made of treated pine logs bolted to plates and these are bolted to very large metal posts/girders. The plates and bolts are rusted through… 0 17115 Need to remove glass panel out of concrete without wrecking the glass to get the spa room in, any recommendations on how to do that. Thank you 0 39626 |
