Browse Forums Landscape & Garden Design 1 Dec 26, 2023 10:48 am Hi I've just not to long ago turfed my backyard but sadly I trusted a couple of friends to do it and to my disappointment they dug up the ground with their feet as they laid it and so I ended up with a terribly bumpy lawn. Well another concreter friend told me to use crusher dust to level it and so i bought sit and he spread it. Problem was it was wet and so it clumped everywhere and I mean big clumps and my grass is dying underneath it. My grass was healthy and all green before he spread the crusher dust, but he didn't really spread it as it clumped and he left it like that. This was 2 days ago and I noticed my grass not showing through so I've tried hosing it in and my grass is yellow under the crusher dust, so now it's patchy and I'm devastated. Was it the right thing for him to do as in spread wet crusher dust over green grass and leave it? It's no leveller now either. HELP Re: crusher dust to level lawn 2Dec 26, 2023 12:29 pm So your lawn is probably totally ruined now. I'd be surprised if you could bring it back, also, crusher dust will be full of coarse grained material and it will wreck your mower. I'd dig the whole lot up and start again. Googling what to do would have been a better idea. Use washed sand or an 80/20 sand loam mix next time, something specific for lawn. Not every lawn is perfectly level and the lumps and bumps will disappear over time with mowing and top dressing. Perth Re: crusher dust to level lawn 3Dec 26, 2023 2:39 pm ![]() So your lawn is probably totally ruined now. I'd be surprised if you could bring it back, also, crusher dust will be full of coarse grained material and it will wreck your mower. I'd dig the whole lot up and start again. Googling what to do would have been a better idea. Use washed sand or an 80/20 sand loam mix next time, something specific for lawn. Not every lawn is perfectly level and the lumps and bumps will disappear over time with mowing and top dressing. omg really..... I'm devastated and I can't really afford to do it again, but thank you for your reply Re: crusher dust to level lawn 5Dec 31, 2023 11:34 am The grass shouldn't go yellow, I've never had my lawn or seen others yellow after top dressing with sand. You should have green start pushing through within a few days if the coverage is thin enough. If you have sections that are too thick it will turn yellow and die. The other problem is the crusher dust may get quite warm (too warm for the lawn) and basically start cooking it. Same thing happens in the middle of summer if you don't water your lawn and it gets too hot for long periods, the lawn cooks, dries out and dies. If you can thin it out more with a lawn levelling rake or normal garden rake I'd try to do that and rake off any excess, that might allow you to save it. Perth Re: crusher dust to level lawn 6Dec 31, 2023 8:50 pm ![]() The grass shouldn't go yellow, I've never had my lawn or seen others yellow after top dressing with sand. You should have green start pushing through within a few days if the coverage is thin enough. If you have sections that are too thick it will turn yellow and die. The other problem is the crusher dust may get quite warm (too warm for the lawn) and basically start cooking it. Same thing happens in the middle of summer if you don't water your lawn and it gets too hot for long periods, the lawn cooks, dries out and dies. If you can thin it out more with a lawn levelling rake or normal garden rake I'd try to do that and rake off any excess, that might allow you to save it. they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 7300 interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 48385 Move your linen into laundry and access laundry from your present linen space 1 8901 ![]() |
