Browse Forums Landscape & Garden Design 1 Nov 11, 2023 3:52 pm I've got a challenge here. Background is the builder has cut too deep for the slab and the slab is now below the very substantial retaining wall. It's failed occupancy as the rules are that there needs to be a fall away from the slab. There's a Ag drain about 50cm out from the slab and that works great. In 2.5 years I've been here water has never pooled so i'm not that concerned. So the first question is - does anyone know of any rule that'd allow me to exempt from this building code? 3.1.3 https://ncc.abcb.gov.au/editions/2019-a ... 3-drainage Failing that, any suggestions on how to get to a pass? I really really dont want to dig out around the base of the retaining wall. There might be other options but all I can think of is a v shaped cut out, or small retaining out from the wall that allows me to cut down for the slab fall away. Hoping for any advice. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks for replying. In my case, there’s no house for the weather to run back on to. There’s just a free fall to the ground, 3 m below. The balcony has 3 posts at the… 11 21611 No. You only have to restrict the opening of any window when the opening starts below 1700 finished floor height or there is a transom or other climbable surface (toilet,… 1 14400 ![]() 1:100 fall is required, a drain and the threshold is also required 6 12223 |
