Browse Forums Landscape & Garden Design Re: Advice for grass in clay soil 4Feb 26, 2022 9:39 am daMuzza The weird thing with the fabric is seems to be everywhere I dig. This is across an area about 2m x 12m. They seem to have covered the whole area in this fabric then dumped clay and rocks on top of it. EDIT: Perhaps is 'Landscape Fabric' that seems to be intended to stop weeds, but has generally negative comments associated with it when I google it. Well that might make it easier to remove the crappy soil on top of the fabric. Might be worth cutting a small section and checking the soil quality below the fabric. I've dug some footings to embed a post anchor into. My holes are around 450mm deep which I'll put a 200mm stirrup into. The bottom of these holes seem firm enough. … 0 3423 DIY, Home Maintenance & Repair Please help me to answer this question , it will help me a lot as i can go to buy confidently with your recommendation: I want to put synthetic turf in our backyard for… 0 5627 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 19149 |
