Browse Forums Landscape & Garden Design 1 Nov 22, 2021 8:52 am I have recently moved into a new home and have some issues with water laying around after rain (blue circle sections) I am on a gentle sloping block with the downhills where the red arrows run and the red x being the low points. I'm not sure what to do re trying to add some drainage. I did look at running an agi line but I have read not to run it into the storm water drain system. Where else would it go? I am wanting to remove the grassed section between the boundary and the house and do all garden if that makes any difference at all? I know I sound daft, but I literally have no clue. Any help appreciated. Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Drainage help 2Nov 22, 2021 10:59 am Rhetski I did look at running an agi line but I have read not to run it into the storm water drain system. Where else would it go? It has to be connected to a silt pit which discharges to the stormwater system. It can't be run directly to the stormwater. Turf is a great dispenser of water, it sounds like insufficient soil preparation prior to laying the turf. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12288 2 5858 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3148 |
