Browse Forums Landscape & Garden Design 1 Nov 20, 2021 10:30 am Hello, I'm in need of some urgent advice to save one dying lilly pilly in the middle of our hedge. Please see the photos attached. The growth seems to have completely stopped and leaves are becoming more sparse as they fall off. A few branches have completely dried up and died. Some of the leaves are turning yellow. I have read this may be a result of root rot. Can anyone confirm this and if so is it possible to save it? Love to hear any and all thoughts/advice. I measured the pH of the soil at this plant and it appeared alkaline. However the trees on either side of this dying plant don't seem to have any issues at all. All of the trees are being attacked by little green bugs but I am managing this with eco-neem and eco-oil spray. Cheers, Jarryd Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17286 Thank you so much for the effort. We will use it to talk with builder. We also had idea of building duplex instead and seeking suggest ions. viewtopic.php?f=31&t=106744 11 13830 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6899 |
