Browse Forums Landscape & Garden Design 1 Sep 15, 2021 2:21 pm Hi, So long story short I have killed off my existing grass lawn (Couch) with Roundup, so I can lay a new Sir Walter Buffalo lawn in its place. I gave it a damn good spray and left it 3 weeks and the whole lawn went very brown and dead , then I came through with a turf cutter and I have taken off all the top and chucked it in the bin , this leads to my question , underneath there are still roots left over from the old grass, do I need to remove them as well? or will the round up kill them off as well? I will add , I did use a lot of round up concentrate so initially it did get a good going over ? Cheers Ryan DIY, Home Maintenance & Repair You might want to consider trenchless pipe replacement to solve the issue of roots blocking your pipes. By connecting the three upstairs bathroom… 3 1767 0 1474 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6288 |
