Browse Forums Landscape & Garden Design 1 Jun 25, 2021 11:41 pm Re: private stormwater easement enquiry - Would anyone please know what easement for support means 0.20 wide, is that the size of pipe that drains the stormwater. I am also trying to determine what internal diameter a pipe (through easement) needs to be to drain stormwater for 2 lots, thanks in advance. Stormwater Easement - enquiry 2Jun 26, 2021 10:53 pm I don’t think an easement for support is not for stormwater, it means you can’t undermine a wall in that area. I think you need an easement for drainage or services best seek advice from a surveyor or solicitor The pipe would need to be 100mm pVC, unless the flies are high which would need 150mm DWV PVC Re: Stormwater Easement - enquiry 3Jun 30, 2021 4:09 pm Pulse I don’t think an easement for support is not for stormwater, it means you can’t undermine a wall in that area. I think you need an easement for drainage or services best seek advice from a surveyor or solicitor The pipe would need to be 100mm pVC, unless the flies are high which would need 150mm DWV PVC Pulse, Thank you for your reply, I think I better go and get legal advice as no one has really been able to assist in my enquiry. Re: Stormwater Easement - enquiry 4Jun 30, 2021 4:12 pm Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17154 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16145 Thanks - yea sounds like I need to submit build over easement application....ugh guess I better start finding someone who can do the engineering drawings 3 3356 |
