Any way to get a free standing fence that doesn't blow over?
I was thinking of that temporary 'construction zone' fencing with the concrete feet and aluminium wire - but they're way taller than I need and they look mighty ugly.
I also thought of using outdoor umbrella footings with a pole and attaching merbau screening to those, but I fear it'll still blow over in the wind.
I even thought of the office cubicle divider feet - like those carpeted panels for office cubicles with the T-shaped recepitcle feet - but I can't seem to find any for outdoor use that would withstand wind blowing on the panel.
I'm out of ideas - anyone have any thoughts?
Source: we had some dark coloured fencing panels put up on our property by the guys at Fences Adelaide. They were pretty easy to set up and cheaper than a full blown fence.
Hope that helps! Good luck OP
Hope that helps! Good luck OP[/quote:2prlgj42]
Thanks mate! Yeah nah I can't put anything down onto the concrete like posts or even bolts. It has to be a movable structure.
I was thinking of one of those vertical awnings that pull outwards, kind of like an airport queue barricade strap lol. But they also need a post bolted to the ground to receive the other end.
Not sure what else I can use other than a ton of plants which I don't really wanna take care of!
If you need to move it - drain water.
The pots can be whatever style, size and shape you need to make it work.
4
Using a rivet sounds like a good idea thanks
27/06/2023
4
Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for…
15/01/2024
I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to…
