Browse Forums Landscape & Garden Design 1 Dec 29, 2020 12:21 am Hi All I am about to begin diy building retaining wall to hold some soil in the back yard and then on the front yard as well. I initally planned to use 2.4m H4 treated pine sleepers, went to Bunnings today and I saw 1.8m are also available. Thinking 1.8m will be easy to install than 2.4m because I would be able to lift / shift the sleepers on my own whereas for 2.4m i would need someone to help me. Is there any downside of using 1.8m VS 2.4m or 3.0m for garden beds/feature 400mm and 600mm high ? (forget about the cost its a negligible difference) Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5099 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6573 Iām just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 52849 |
