Browse Forums Landscape & Garden Design Re: Need help with west facing wall. 3Jan 21, 2021 1:04 pm How about https://www.smartstonesystems.com/fibro ... t-cladding ? These are thick XPS foams with a thin layer of stone veneer at the face side. The other side can be clamped straight into the brick wall and the gap between the panels are filled with adhesive.
Hope this would give you some alternative ideas, good luck and all the best! Cheers LG Re: Need help with west facing wall. 4Feb 22, 2021 9:55 am ![]() How about https://www.smartstonesystems.com/fibro ... t-cladding ? These are thick XPS foams with a thin layer of stone veneer at the face side. The other side can be clamped straight into the brick wall and the gap between the panels are filled with adhesive.
Hope this would give you some alternative ideas, good luck and all the best! Cheers LG Only just noticed your reply. Thanks very much for the info and link. I will do some research. hey, i am in a similar situation. Which one would you recommend and from where can I get that? 8 2187 Thanks for letting me know, could you tell me what size windows you have though in that space? I will have solar so can run air con pretty much all the time but just not… 4 1404 17 4418 |
