Browse Forums Landscape & Garden Design 1 Dec 03, 2020 9:12 am Hi, i have just installed the following 4x 1.8m led strips under benches (4.5watts each) 8x 5w spotlights the led driver i am using is a ROBUS 100w driver. Issue i am having is that when all lights are connected they flash... when i remove the last 4 spot lights the rest of the lights work fine? Total run from power to last light is roughly 24m. Any ideas on what could be the cause? Perhaps its the driver? LED 12V Garden Lights flashing 2Dec 03, 2020 7:12 pm Need more info What strip lights, what spot lights, which Robus 100w driver?? All these lights are in series? I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf 2 10623 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6271 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10139 |
