Dromana Toppings - Question
Damped down the toppings very lightly before using a plate compactor. Brushed off as much of the ridges caused by the compactor as possible but these still show and I'm not happy with the overall finish.
How can I smooth these ridges out of the toppings? Can I run a compactor over the toppings once they've dried out and hardened? Do I need to damp them down again before compacting again?
Any help or advice on the best way get a much smoother surface would be great.
2
You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap…
20/07/2023
1
I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If…
7/08/2023
1
how imperative is the timing of the answer?
