Browse Forums Landscape & Garden Design Re: Where can I buy quality Irrigation Tube? 13Mar 05, 2010 3:56 pm You are allowed to install it your self and because it isn't connected to the mains water supply the use of a licensed plumber won't be required. In those cases a special valve must be installed and certified by a licensed plumber. It is called an RPZ valve and is a seriously expensive bit of gear. That is what makes using these setups with mains water too costly and therefore gear driven sprinklers and MP's the better option. For grey water it is fine. Just review the threads and links I have posted and all the info you need is right there including your nearest supplier Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20760 Hi Brainstrust, I had a go at creating my own irrigation plan, keen to get some feedback. It will be run from one 750-800W pump, off 2* 5000L rain tanks. Each zone… 0 23263 It's MGP 10 which means every length has been machine graded to it's specified engineered strength. It may not look pretty and if you where hand picking your timbers you… 1 1042 |
