Browse Forums Landscape & Garden Design 1 Nov 28, 2008 1:34 pm I bought some Weed'n'Feed the other day and after reading the label it said not to be used on Buffalo grass.
I have no idea what type of grass I have and was hoping someone might be able to tell me. Hopefully these photo's tell the story. Cheers Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: What type of grass do I have? 2Nov 28, 2008 3:15 pm That looks to me more like kikuyu than buffalo.
But I wouldn't take my word for it--wait for a consensus! --Mike Everything I know, I learned from SBS. LATEST: Frame Complete http://metricon-mercer.livejournal.com Re: What type of grass do I have? 4Nov 28, 2008 6:48 pm I’m not a hundred % sure what it is.
This is Buffalo, or now as well called Sir Walter. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Kikuyu Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: What type of grass do I have? 5Nov 28, 2008 6:50 pm By the way, Buffalo is very hard to touch, its not a soft grass, buffalo grass is the main one to give you grass burn if you roll around on it. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: What type of grass do I have? 6Nov 29, 2008 8:54 am Its Kike What sort of weed and feed do you have?
I never suggest using the granular ones too often, they are very bad for the environment. When choosing a concentrated weed spray for your lawn you will need to look for one that doesn't contain "Dicamba". try one in an orange box called "Bin-Die" by Amgro. The weed and feed may cause your Kikuyu to go black. It is tough and might come back https://forum.homeone.com.au/viewtopic.php?p=110291 Re: What type of grass do I have? 7Nov 30, 2008 9:35 pm Thanks for thta Fu Man, I bought the yates weed'n'feed in the bottle that you click you hose onto and spray around, I did it this evening so I'll see how it all goes.
I did have a huge bindi problem that I solved partly by picking them out but initially by using that stuff in the orange box you suggested. The Bin Die and another one form the same mob. I mixed them together and sprayed the lawn a few months ago. Thanks again for all the help. DIY, Home Maintenance & Repair Please help me to answer this question , it will help me a lot as i can go to buy confidently with your recommendation: I want to put synthetic turf in our backyard for… 0 5542 Natural stone tiles like slate, travertine, and limestone add a timeless, elegant look to… 0 24952 2 4187 |
