Browse Forums DIY, Home Maintenance & Repair 1 Aug 09, 2020 3:21 pm Hey guys, just wanting to hook up an Ozito water pump to existing water tanks to use with an irrigation system I just installed. I have the water tank adapter kit but the water tanks were already fitted with a tap outlet (see pics) is there any way can fit the flexipipe to the tap? Or will I have to take the tap off? Really trying to avoid the latter as the tank is full! Thanks 😊 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Pump for water tank? 2Aug 09, 2020 4:19 pm Just take the sprinkler adaptor out, check the thread size and buy a poly nipple to suit. The nut and tail then connects to the nipple. BTW, the tank outlet is a drain valve, its not ideal for the pump to be drawing water from the anaerobic zone so close to the sediment layer. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Pump for water tank? 4Aug 09, 2020 4:46 pm You need to leave the gate valve and just replace the sprinkler adaptor. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. 18 90480 From what I know about water tanks (I've been working with a client on them for a few years now) is this - The concrete can last a lifetime if they don't crack for some… 2 10629 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17530 |
