Browse Forums DIY, Home Maintenance & Repair 1 Apr 15, 2020 5:23 pm G’day everyone, I’m currently doing a polished concrete dining table (1850 x 900 x 50). Still having a bit of trouble on how to connect my steel frame (legs) to stop the slab from any movement (even though extremely heavy). WHAT IF... I glued rubber matting to the top of the frame to go in between slab and frame. Will this be enough to keep it in place?? I’ve ruled out drilling into the concrete after it has set as risk of cracking. The best I’ve got at the moment is to pre-set threaded rod into the concrete.. Thank you!! REPLY Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Rubber matting under concrete table?? 2May 20, 2020 11:27 pm Never had any problems drilling concrete when it has set. Start with 6 mil masonry SDS + drill bit and then you can work up to the size you need getting the bits thicker by 2 mil at a time. Never had I any cracks this way. It's easier than drilling tiled surfaces. Re: Rubber matting under concrete table?? 3Jun 03, 2020 12:20 pm just place your top on the support frame, get underneath and run a bead of silicon around it. If you ever want to take the top off,get a sharp knife and cut the bead. Hi there, looking to have a gym in a new build. Planning to install some sort of rubber mat flooring (on concrete) i.e. Asking the builder to not do floorboards in the gym… 0 1378 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10168 Hi, Really struggling to find some consistency amongst Span Tables, can anyone help… 0 2670 |
