Browse Forums DIY, Home Maintenance & Repair 1 Mar 28, 2020 10:40 am Anyone know whats happening here? My front door wouldn't unlock the other day. I could turn the key and the latch would move but would not withdraw fully. Ive taken the lock apart but still cant get it to unlock. Any ideas? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Front door lock jammed 2Mar 28, 2020 2:22 pm Hi swat Have you tried just grabbing the tongue of the latch and manually pulling it back. That should open the door. If it's hard to do that it's possible the door has developed a bit of a bow and you may need to push the door to relieve the pressure on the latch. What sort of lock is it. It looks like a Gainsborough Trilock or similar? Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Front door lock jammed 3Mar 28, 2020 6:52 pm Looks to me you need to get a big flat head and try pull the barrel back in. Good luck Registered Building - Always happy to help where I can and simply loves the game. DM me if you need help in VIC. That would be what I'd expect if you upgrade a trilock to a trilock omni. You are looking at roughly $200-$250 extra for the hardware then a bit extra for fitting and… 3 1148 ![]() chennaiite I think what you meant to say was different size goings. In modern landscaping it's common to mix a couple of steps with big landings of different sizes. It… 7 5512 ![]() I can't decide what door size to put as my front door. I have a 12m wide house with a 6.35m wide garage. Ryde facade from MacDonald Jones home building Albany two. My… 0 1586 |
