Browse Forums DIY, Home Maintenance & Repair 1 Dec 20, 2019 5:56 am Hello! Just wanting some advice on paint removal. Our house is new, and when we had a concrete path installed around the exterior recently, it was a windy day and the concreter accidentally sprayed dark grey paint onto the cream rendering at the front of the house. He hasn’t responded to messages asking him to please fix, so we’ll need to. Should we use paint thinner, or will that remove the rendering paint too? Or will we just need to repaint that whole rendered section? Thanks very much for your help! Re: Paint splash on rendering 2Dec 20, 2019 6:38 pm Pool acid will dissolve concrete, of cause it is acid so be careful also test it won’t affect your paint. I used to clean concrete off tools this way in a previous life Re: Paint splash on rendering 3Dec 21, 2019 5:07 am Mandi Hello! Just wanting some advice on paint removal. Our house is new, and when we had a concrete path installed around the exterior recently, it was a windy day and the concreter accidentally sprayed dark grey paint onto the cream rendering at the front of the house. He hasn’t responded to messages asking him to please fix, so we’ll need to. Should we use paint thinner, or will that remove the rendering paint too? Or will we just need to repaint that whole rendered section? Thanks very much for your help! Both the paints are water-based (Acrylic) so no matter what you do you will damage one or the other. Unless it comes off with water and rubbing. Best to just get some touch-up paint for the render. I assume it is painted and not pre-coloured render. Our Bondi Greenwall was impressive from day one with advanced lush plants to provide a wow factor to this recently renovated living area. The boundary was less than 1… 0 15309 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4897 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7497 |
