Browse Forums DIY, Home Maintenance & Repair 1 Dec 02, 2019 8:20 pm Hi, We jsut painted our roof. Spent two days cleaning the roof. We hired an industrial pressure washer to remove all old flaky paint and prepare the roof for painting. Hired an industrial paint sprayer, prepared paint according to instructions, did two coats of Dulux roof paint and used 7.5tins to cover approx 200sqm. The final result looks very patchy. Andy advive? Please see photos. We did not change paint colour. After two coats of Dulux roof paint (7.5 tins used for two coats of approx 200sqm)Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ After pressure washing and cleaning Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Post two coats of new paint Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Freshly painted roof - looks patchy 2Dec 05, 2019 11:09 pm It looks to me that it hasn't enough paint applied, Did you water it down at all? Perhaps spray too far away from the roof and lots of dry mist? Re: Freshly painted roof - looks patchy 3Sep 22, 2021 2:32 pm Rachy did you end up resolving this problem? We are currently going through the same experience. We have painted the verandah and double carport so far with Wattyl Solagard Satin in Colorbond Surfmist and have the same patchy result. We have 1 coat of primer and 4 top coats (long story) so there is definately enough paint on there. It appears to be more an issue with an inconsistent sheen or finish. If you look across the roof or in shadow it looks fantastic. On the glancing angle, in line with the corrugation in full sunlight it looks very patchy. In particular where the overlaps are look different to the areas with no overlap. Hi Everyone, Ripped up the carpet and the surface below gas come loose and you can see the slab below. The material breaking away looks and feels like crumbling cement.… 0 8770 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 3808 Thank you Pulse, I thought we did the right things; external shutters on all windows down all day, west side of the house nearly completely in the shadow of the large two… 6 25111 |
