Browse Forums DIY, Home Maintenance & Repair Re: How to fix the crack? 8Aug 13, 2019 2:45 pm CarnTheHawks 100% When there's movement between two hard objects, "something's gotta give". So the render connection to the window frame broke, now leaving a visual eyesore, and place for pests to visit Thanks, BTW -- how can you tell there is no seal / buffer between the window frame and the outside render??? I google some pics but can't tell it very clearly. Re: How to fix the crack? 9Aug 13, 2019 5:57 pm The bulb seal should be minimum 5mm, and the foam butts into that. Several mm of render, Inc base & top coat. Still room left over, visible seal & expansion/articulation capability. I don't believe this was done. Photos with more focus & different angles would help. An easy to view example is facade windows. The sills should be very shy of the frame underneath. The seal underneath is 10mm+, and the sill should be built another 5 below that. You can easily build-up the render to remove the gap. If you render on the seal a bit, no major issue. But render to the frame leaves no room to move, and needs cleaning off. Most likely poor foam installation and render installation, Joint covered with render, foam could be sitting on flashing. Do you have any render at house 4 9316 Hey guys, what’s everyone opinion on James Hardie linea direct fix to frame? Would this be the most common method and anybody ever had any problems down the track? 0 5151 DIY, Home Maintenance & Repair If the railhead is so poorly fixed it is also likely that the railhead is also non compliant, what about overflows and sealing railhead to the gutters?. 3 5971 |
