Browse Forums DIY, Home Maintenance & Repair 1 Aug 12, 2019 4:46 pm Hi. There was mould all over the bathroom ceiling and wall and I took it upon myself myself to remove all the paint and repaint the whole wall and ceiling. I have removed all the paint; however, the plaster that was behind the paint seems like course cement. It is brown and not at all smooth. As I rub my finger against the wall sand particles fall down. Should I go ahead and start the painting process or should I replaster the whole wall? Please help with advice. Thanks in advance. [img:10wrfgig]https://forum.homeone.com.au/u/91009_1565592313.jpg[/img:10wrfgig] It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17191 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 9755 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10614 |
