Browse Forums DIY, Home Maintenance & Repair 1 Jun 03, 2019 9:38 pm Hi guys I’ve tried to install an electrical wall plate by cutting through plasterboard with a c clip although there is a stud in the middle and can’t get the wall plate fully onto the clip because of the stud, the clip doesn’t seem to be able to move back after being screwed onto. Do you guys have any other ideas on how to attach the wall plate? Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 9124 That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8640 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5179 |
