Browse Forums DIY, Home Maintenance & Repair Re: Crumbling brick wall 4May 20, 2019 8:10 am geroranger Hi, would you have any suggestions of a brick sealer to buy that you have used? Most products I've bought from Bunnings seem to be 'diy' strength and fail not long after I buy it. Is there a professional product you use? Thank you I don’t have a product to recommend, but you could search the Internet for "professional grade masonry sealer" or speak to a local masonry specialist. can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 4470 Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 7945 Building Standards; Getting It Right! Hi all, My neighbour has built his 15m long garage on our boundary. It was agreed as part of the planning permit that the wall must be in exposed recycled brick. For some… 0 10916 |
