Browse Forums DIY, Home Maintenance & Repair Re: Rheem solar hot water long roof sensor replacement 3Apr 18, 2019 7:55 pm You might really enjoy these people.....parts, technical advice, installation vids......
https://www.solarhotwaterparts.com.au/s ... k-sensor-1 Re: Rheem solar hot water long roof sensor replacement 4Apr 18, 2019 8:32 pm Mike8136 Perhaps pull off the sensor and take it to an electronics store (Jaycar for example). It's probably a standard thermocouple (pt1000 or similar) that you could wire back to the controller. If someone can identify it there is no need for an OEM part. Thank you. I will give it a try. Re: Rheem solar hot water long roof sensor replacement 5Apr 18, 2019 8:39 pm kks You mind really enjoy these people.....parts, technical advice, installation vids...... https://www.solarhotwaterparts.com.au/s ... k-sensor-1 Thank you for the link. They have long roof sensor that I need. https://www.solarhotwaterparts.com.au/sensors/roof-sensors/rheem-drain-back-long-roof-sensor The website is based in Queensland. I try to find a store located in VIC. Re: Rheem solar hot water long roof sensor replacement 6Apr 18, 2019 10:59 pm The part will post to you easily. I like their video guides, most informative. We had a real good run with our Rheem solar installation. Replaced the ground based tank once and a couple of pressure-release valves on the roof collectors. Only replaced it when gas came to our area and we went with an instant gas system. I'm curious, did they provide any reason why they did not like the idea? 1 13016 We're looking at replacing the roof of a heritage listed home so it needs to be terracotta tiles, wondering if anyone has any recommendations, hints or… 0 1377 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 13618 |
