Browse Forums DIY, Home Maintenance & Repair Just try backing of the closer. On the end of the closer that attaches to the door is a screw. Try undoing it a quarter turn at a time. The more you undo it the harder… 2 1761 ![]() Raise all plaster cracks to builder at 90 day and then within 2 years of handover so they can be repaired and investigated if required. Take lots of photos. Read the… 1 586 What they can do without cutting the slab is to install the door over the step down and set it so the bottom is flush with height of your finished floor level ( say you… 5 2166 |
